Zoom Icon not Available
in Rife Posts: 6
Hello. I have installed the Woor Theme but i dont have available the zoom icon in the images of indivudual product at Woocommerce. Instead, i installed another theme but always the same. No zoom Icon in images of indivual product. I want the zoom icon and their effects at the images. Thanks
    Can you share a live link?
    Based on the links to the previous and next under the image, I suspect there is some plugin conflict.
    https://penart.es/producto/la-luna-2/
    if you need anything else let me know
    3840 x 2160 - 801K
    3840 x 2160 - 733K
    As I don't know all the plugins you are using, please try to disable all plugins except for:
    -Apollo13 Framework Extensions
    -WooCommerce
    -Elementor
    Check then if it will be alright. If yes, reactivate one plugin at a time.
    It's already fixed, it was a plugin. Thank you very much Air.
    Soon I will write to you again with more doubts. hello2
    3840 x 2160 - 2M
    - Royal Elementor Addons.
    It's the one that gives me problems.
    Do you mean this one https://wordpress.org/plugins/royal-elementor-addons/ ?
    I will take a look if I can find anything easy to fix with it.
    Exact. He was the one who gave me trouble with the magnifying glass. If the problem is solved tomorrow, I would like you to let me know. Thanks for everything.
