Hello. I have installed the Woor Theme but i dont have available the zoom icon in the images of indivudual product at Woocommerce. Instead, i installed another theme but always the same. No zoom Icon in images of indivual product. I want the zoom icon and their effects at the images. Thanks
Can you share a live link?
Based on the links to the previous and next under the image, I suspect there is some plugin conflict.
if you need anything else let me know
-Apollo13 Framework Extensions
-WooCommerce
-Elementor
Check then if it will be alright. If yes, reactivate one plugin at a time.
Soon I will write to you again with more doubts. hello2
It's the one that gives me problems.
I will take a look if I can find anything easy to fix with it.
