Hey there! Very nice theme! Got one question (for now ). I turned off the Blog side bar (Hypershot theme > Blog & Archives), but somehow the sidebar still shows up on the main (blog) page. Any idea how come?
If I remove the widgets from the Blog sidebar everything is okay. But I want to have a side bar displayed at the single post page, just like your demo. Any ideas?
Hey, Sorry, the blog is masonry blog style. I'm sorry but I'm having some problems with my site, so I can't send you a working link right now. I do have the exact same issue as the thread you posted, but I do not see a solution in that thread..
Thanks for answer. I have just checked my version few times in different config and I still can't reproduce this issue. Could you please send me temporary access to your WP and FTP so I could check there what is going on? Send it here on forum via private message.
Yea good indeed :-P Still I need someone to give me access to his installation so I could find why you encounter this issue. Meanwhile I will try again to recreate this issue on my installation.
BTW: can you please tell me where the option is stored in the database? maybe there is something wrong in our case - as it's not a problem for most user...
OK. AlvaE that was big help!! Thanks a MILLION! So it turns out to be two things. One is that: if you setup your theme like here http://apollo13.eu/docs/hypershot/#!/adding_frontpage (set some empty page for front page) and then choose in theme settings to use blog as main page then it would work proper.
Second is that, that I wanted to be bulletproof for such situation but I made check points in not proper order and that is my issue.
So to solve it you can either use above solution or/and change code in advance/utilities.php line ~175
Any ideas?
You can also send link to your issue so I could see it on my own, also useful information would be telling if you use masonry blog or classic style?
Just like rim_light the masonry blog shows up like this:
https://dl.dropbox.com/u/2188035/front.png
Just like rim_light I TURNED OFF the side bar like this:
http://dl.dropbox.com/u/2188035/blog-archives.png
The side bar, however, still is being displayed. Maybe the function 'blog sidebar' isn't working properly?
Regards
Thanks for all help.
line ~175 to It will land in next update. Thanks again.With regards.
