It is not just slider it is your whole page JavaScript. I see you are linking to newest jQuery available which is very wrong as old libraries depends on many things that are removed in newest version. Stick with jQuery. 1.7.x and you should be safe, and also look out for Wodpress updates.
You are still using jQuery 1.9 :-) I don't know what you have installed there, but it is messing much. If you like send me temporary access to your WP and FTP so I could check there what is going on? Send it here on forum via private message.
I think I know what could be the issue. Try using this file http://support.apollo13.eu/discussion/comment/2798#Comment_2798 it should fix theme working with WP 3.5
But Slideshow is still spinning on the front page.
Check it out:
http://coldfusionnow.org/
It just happened last night. What could have changed?
Can you suggest a theme that is similar? Here's the site:
I like Airlock, but don't think I will be able to fix it. Is there a theme similar, but updated to go with the Wordpress they are using now?
It shouldn't be hard to fix it :-)
I sent you a message.
