Hi
I have created and selected an album to be 'background only' to act as a landing page however the album is appearing as an album title on menu as 'front page' - www.georgeangelovski.com
Does anyone know how to remove the album title from the menu?
Thanks in advance!
You mean that title of album shows as title of front page? This is nothing to do with "background only" option if you selected album as your front page.
If you would set static page with background album, then it would be different story :-)
Anyway not longer then 4 days ago there was almost same topic http://support.apollo13.eu/discussion/1037/homepage-title-tag-re-writing-problem/p1
