From what I can see you have too many items in your first level menu. I would advise to reorganize it in sub-menus. Menu in Hypershot theme is only one row.
These are not full-screen :-) Also when you post, then please describe what is wrong in each screen shot, cause on two of your pictures I saw nothing wrong.
sorry i don't want to you show you full screen shots. But you see the problem and i will describe it again.
-The titels of the albums are still there. In working browers you must to the album with the mouse to see the titel. In the 64bit ie8 its always shown.
-the shading of the albums are only black, where are the lines?
-And contact is in the second row and i don't know why. In other browers is everthing ok
Hehe, man this 64bit was so misleading in this whole topic. It ends up that normal 32bit IE 8 is same in your issues:-)
dang360 said: sorry i don't want to you show you full screen shots.
Why is it so? Aren't you here to get help? I was interested to see it mainly for menu issue cause I am most concerned about it. Live link will be even better. You can always send it via private message(click on my nick and there you will find option to send message) . In message please attach link to topic it applies to.
dang360 said: -the shading of the albums are only black, where are the lines?
No lines in IE8, as it doesn't support pseudo elements good. I think that opaque color is good fall back solution.
dang360 said: -The titels of the albums are still there.
I have checked your site, and issue is as I supposed: There is not enough space for menu items to fit in IE 8. This browser calculate a bit different fonts, and by that it steal precious pixels :-)
There are several things you can do about it: 1. Make your logo narrower. 2. Switch to wide appearance Hypershot theme-> Appearance-> Main appearance settings-> Layout style 3. Hide some menu postions to submenu. 4. Write special CSS for IE 8 that will make it fit :-)
And thats "Contact" falls in the second row is only one problem.
-the titels from the albums are still there.
-there is no shade anymore, just black if i move my mouse cursor there.
I will help you with 4 point if you decide on it.
and the problem with the titels of the albums?
thank you Air
