Hi all,
First of all, I would like to congratulate you for your great job on this template. It’s just awesome.
My main problems :
1/ Video autostart doesn’t work on iPhone and iPad on video template galleries such as showreel video gallery ☹ How can I solve that ? Video galleries with Brick design work very well anywhere but it’s like there’s something wrong with video player in fullscreen on mobile devices. Can you look at it?
2/ The button to open menu for small devices “blink” on iPad. I mean it’s almost impossible to open easily the menu with this button on iPad. In same time, it works very well on iPhone… Have you got a suggestion?
I have as well some questions about customization, I will ask them on a separate topics
Kind regards,
Jimbo
Thanks for your kind opinion about our work, we appreciate it :-)
If you have more then one case to talk about then please add every case in separate topic, cause if this topic will have more then 3 answers, it will make chaos by answering to different points of first question. I believe you can imagine this :-)
1. I explained it few times already that iOS video player has its own limitations, and autoplay is one of these limits.
2. http://support.apollo13.eu/discussion/comment/2829#Comment_2829
Regarding these limitations, can you think is it possible to have a little workaround, for example to show a thumbnail of the video instead autostart?
Thank you.
I don't remind to see ever thumbnail on mobile, so it might not be possible. Have you ever seen such thing?
Kind regards,
Jimbo
http://apollo13.eu/docs/hypershot/assets/images/image_8.png
