Page password for one special category
edited May 2013 in Hypershot Posts: 40
Hi Air,
first of all: My page looks amazing now!! Thanks for your theme AND help!!
There is only one thing missing for the relaunch :)
My question/feature request:
On my old page I had a category, which was only readable for friends etc. I had a protection for the whole subpage based on archive/blog templates.
The rest of the blog was open for all (and the protected posts were not shown - we had this topic before and this is solved! Thanks!)
the code was like this:
<?php get_header(); ?>
<?php if(post_password_required()){ echo '<div class="password-protected-page">'.get_the_password_form().''; }else{ ?>
everything that should be hidden
<?php } ?>
<?php get_footer(); ?>
How could I manage this with your theme?
I tried to use a copy of the archive template... but it didn't work out well :)
There are several plugins which do stuff - but not the way I need it.
To put it in one sentence:
It would be great, if I had the option to have the standard blog AND the password protected archive/blog page, which only shows posts of the private category (even a simple link for the menu would be fine!)
Is this some how possible?
Thanks for reading so much text!! :)
All the best
Max
Post edited by macmacs on
    macmacs said: Thanks for reading so much text!! :)
    I have to read longer ones, unfortunately ;-)
    About your request it is not easy. You can add, every password protected post to certain category, and then link it in menu(it is possible in any theme), but it will make this posts also visible on main blog page(but with required password).
    You can try to hide this category on main blog page with some plugin.
    I know it is all probably obvious what I wrote here, but maybe it is somehow helpful.
    Well, You were right :) It is a lot of work.
    But no matter what, I figured, for it is MY wish, I should work it out by myself :D
    So, I found a way. Basicly copying some templates (frontpage,loop,...) and adjusting them to my needs.
    If anyone was interested in this customization, I'd write it down.
    Regards,
    Max
    Pretty nice!
    If you like you can zip your result file and attach it here, but only if you like:-)
    Have a nice day!
    Ok, no problem. I am going to do that once I finished things like adjusting the info bar :)
    Hi guys,
    I collected my files and give them to you:
    1. Put the three php files in the main theme folder (../themes/hypershot/).
    2. Alter the filtered category (here 'protected') in the protected-loop.php to your prefered category name:
    $args = array(
    'posts_per_page' => 10,
    'paged' => $paged,
    'category_name' => 'protected'
    3. create a page based on the protected template and password protect the page.
    4. Exclude the protected category from the main blog (and feed) via the 'Ultimate Category Excluder' plugin
    Now, in there should only be posts with the choosen category in the protected blog!
    Have fun ;)
    Regards
    Max
    zip
    zip
    protected.zip
    3K
    Thanks for sharing this one, looks pretty nice:-)
