Homepage Slideshow Delay
edited August 2013 in Skyfashion Posts: 10
The homepage slideshow has a delay in loading. At first I thought that it may be the size of my photos but then I noticed that the theme demo has a delay as well. Is there anything I can be doing to reduce loading time/delay?
I've also really stripped down the homepage to simply a header, slideshow and a footer. Are there any js file references that I can delete in hopes of speeding things up?
    Sorry, forgot to include link:
    http://audreyclairecook.com/new
    Which delay do you mean? Could you describe it better?
    About js files it is not possible at all because if you disable some files there could be a conlict on other pages. If you want to speed up your wordpress use css and js minificators and cache plugins.
    Kind regards
