I made the navigational bar transparent so my photos could be seen top to bottom without the default "white" navigational bar cutting off the subjects heads. However, even as I made the navigational bar transparent I can't seem to remove the light gray line that separates the navigational bar from the background. You still see the outline (please see picture below)......how do I get rid of that?
You have to add custom CSS like Here you can find way to add this custom CSS http://apollo13.eu/docs/hypershot/#!/modification_of_theme
There is even detailed info on plugin page how to install it http://wordpress.org/extend/plugins/pc-custom-css/installation/ but you can also search for this plugin via your wordpress and make it to do all the "hard work" with installing plugin.
I will explain as far as I can, but I can't explain basics of wordpress, as I am not here for it, but to help you with skin that is made for wordpress.
Please just give another try in reading everything carefully.
With kindly regards.
I also wanted to get rid of the shadow there . I did followed the exact procedure . please see the attachment . But the shadow is still on . would you please help .
cause when downloading , Safari did unzip the folder so I did " upload " only the file called plugin.php and not the file called admin.php .... could it be there ? the problem ?
And while I am here , I did also test my email adress into the contact ... and I m getting my same test email all over again and again every +- 5 minutes
And I can say, that PC Custom CSS works, 'cause it's changing some other colors immidietly.
List of ACTIVE plugins:
AJAX Thumbnail Rebuild
IntenseDebate
PC Custom CSS
Sociable RE
WP Retina 2x
Wordpress version -- 3.6.1.
Hypershot child theme Version 1.3.3
Custom css: url:http://www.mrakor.com
Thank you Air!
