hi there,
where can I Change the contact form? I don´t want this arithmetic problem as captcha (because my font is a Problem when displaying + or -, they look verry similar), and the subject shouldn´t be a mandatory field
and I want to add an extra field
thx
best regards!
Function for printing contact form
a13_contact_form
you can find inadvance/utilities.php
line ~275JavaScript validation is in
js/script.js
formValidation : function()
line ~836.and short answer about extending it http://support.apollo13.eu/discussion/comment/7058#Comment_7058
thanks for answering!
