hi there
when I search my site in Google, in the search description of the Albums is always "Zum primären Inhalt springen Zum sekundäreb Inhalt springen" how can I delete this Phrase or so that it won´t Show in the search results
best regards
PS : i also tried yoast seo but nothing changed
I understand this is hidden links for blind users.
I believe that you know, that changes in your site don't show up in search results right away?
Anyway you have such code in header.php, and you can delete it if you like. With regards.
thanks for your answer, when I delete this, is there any effect to the functionality of the site on normal Desktop pc or mobile devices?
best regards!
