hello
i have a lot of small problem, maybe there's only configuration problem
first in the album page like this
http://www.zicactu.com/clips-video/coldplay/you can listen 2 or 3 or more sounds in the same time
in this page
http://www.zicactu.com/bio/jean-louis-aubert-biographie/i can't put the picture carrousel in automatic
(scrolling pictures automaticly)
i create a lot of album with the parameter "use only as background"
but this album are in the widget "recent album"
i hope you can understand my question
thanks for your help
serge
You are not new here so I hope you can understand and read this.
-to add every case you wish to discuss in separate topic
Anyway: Such setting work only in album and background album, not in flexslider in page. It only pulls there photos from album, nothing more :-) I understand this is not obvious and it is our bad :-)
Use this to change it http://support.apollo13.eu/discussion/comment/3601#Comment_3601
Yes it is a bug and thanks for reporting that! I am just asking to keep order on forum so other user can also find this topic useful. What does current title of this topic tell anyone? Please change it to proper one:-)
If you made each question in separate topic I could even post quick fix for this so others could use it too.
Thanks for understanding.
i don't have permission to update this post..
i read the post about the flexslider but now the file is
jquery.flexslider.js and i don't where i must change the code
Oooo I see, it is old topic where there were some old options also. Go to
hypershot\js\script.js
and search there for what is explained in topic.With regards.
