wordpress 3.9 update
edited April 2014 in Hypershot Posts: 17
hello
if you're using hypershot theme bricks, the theme don't work with wordpress 3.9
  • After the upgrade from 3.8.3 to 3.9 I have the same.
    The albums list at the front page using bricks doesn't work anymore.
    For the time being I switched to a single album but I would like to have a solution for this.
    i roll back to wp 3.8
  • Same Problem, Have rolled back to 3.8 for the time being.
    how you can roll back?
    Hello
    Fast fix: Go to advance\head_scripts_styles.php
    line ~49 change
            //masonry
            wp_register_script( 'masonry', TPL_JS . '/jquery.masonry-with-resize-plugin.min.js', array('jquery'), '2.5', true);
    to
            //masonry
            wp_register_script( 'a13-masonry', TPL_JS . '/jquery.masonry-with-resize-plugin.min.js', array('jquery'), '2.5', true);
    Line ~68 change
    array_push($script_depends, 'masonry');
    to
    array_push($script_depends, 'a13-masonry');
    Update will be released in few hours.
    Same problem with Beach Please!
    Yes, we know and you can apply same fix :-) Update will be ready in few hours.
    You guys also have the problem with the blog looking completely messed up since last WP update? I don’t mean to stress. I read that there will be an update coming soon, but here’s just been talking about the gallery bricks, not about the blog looking strange now.
    (see attached file)
    1200 x 569 - 62K
    Same bricks, same script, same issue :-) Have you applied fix?
    The fix fixed it. :)
    Great:-) I am still working to prepare fixes to our themes:-) Loong night:-) Tomorrow they should be available.
  • edited April 2014 Posts: 8
    I made the code changes AIR provided above and it fixed both the "works" page and the blog roll. I would only add that in Beach Please wordpress 3.9 the necessary code is found under appearance/editor/head_scripts_styles.php. Not under advance in the theme menu. Thanks for the quick fix AIR! http://openoceancompany.com/t-shirts/
    Post edited by Tubalcain on
    Hello Guys!
    The update in now live, you can download it from the Themeforest!
    Best Daniel
    Lead Graphic Designer
  • I applied the fix as described by Air and it works like a charm.
    Thanks a lot for the quick support.
    Kind regards,
    Frank
    Hello
    All our themes should already inform about updates. Thanks for your patience:-)
    Tubalcain said: I would only add that in Beach Please wordpress 3.9 the necessary code is found under appearance/editor/head_scripts_styles.php
    Do you have customized theme?:-) Cause in default installation path is same as in Hypershot and other our themes advance\head_scripts_styles.php.
    Anyway thanks!
    Many thanks for You re reactivity, i m french and sometime s it s difficult to explaim but i understand code
    Hello There, i'm using Beach Please Theme, and I can't update it, once I upload the new zip file, error comes up on wordpress, it said I have to select "upgrade theme" in the drop down menu, but i can't find this menu anywhere...Any toughts?
    Hello there:-)
    Please follow http://apollo13.eu/docs/beach/#!/installation_update_update_theme and read it carefully :-)
