Is it possible to change the option of the image lightbox on products (woocommerce)?
there is 2 default function that I would like to modify:
1. the alt text appears at the top of the lightbox and I'd prefer not to make the alt text visible (only the title below the image). How can I do that (I want to keep an alt text but only visible for google ;-))?
2. there is a navigation bar with all images that appear in the low part of the image, is it possible to let it appear in the white frame below the image (where the numbers of images and title appear)?
Thank you :-)
These are more like Woocommerce and Pretty Photo script questions
For 1. you can check http://www.kriesi.at/support/topic/hide-title-and-alt-text-on-pretty-photo-gallery-images/
For 2. I don't quite understand what to move where, but you can search for it. Search for changes for that script http://www.no-margin-for-errors.com/projects/prettyphoto-jquery-lightbox-clone/documentation/
Hope that will help you somehow.
