Hi, I am having a problem with my accounts page “lost password” link not working. You click it and it redirects to same my accounts page.
My developer who purchased the theme (Beandigitalmedia) have tested with a different theme and this works fine and goes to correct page.
Can you please help - my customers are constantly contacting me regarding this & its causing such a problem for me.
Domain - www.crossdressingcloset.com
Hope to hear from you soon.
Regards
Louise
I have just tested this thing on our server and it works OK and leads http://fame.theme.apollo13.eu/shop/my-account/lost-password/
What version of woocommerce do you use, cause we are just about to test theme with Woocommerce 2.2.x, cause for now we used 2.1.x - maybe there is an issue.
It can also be problem with cached permalinks, but this is just pure guess from me.
Look forward to hearing from you.
Louise
I should have mentioned that before we upgraded to woocommerce 2.2.4 recently, the problem was occuring on the earlier version.
Louise
This problem is in queue, and I hope to get to this today. But: if it is like that then it is possible that is some misconfiguration, hover you may have used 2.2.x from start.
If you like you can send me temporary access to your WP so I could check there what is going on, after I will confirm compatibility with Woocommerce 2.2.x? Send it here on forum via private message(click on my nick and there you will find option "Send Air a Message"). In message please attach link to topic it applies to.
Sorry for delay, we had busy week with updates(that are still not finished:-) ) and server issues.
I have just updated to woocommerce 2.2.4 and I still can get to lost password page. I see we need to update some templates, but this don't affect lost password case. Please send me data like I asked in previous post and I will take a look what may cause this.
However everything is possible:-)
Louise
I am glad that issue is fixed now :-)
We are just about to release update for Fame theme, should be available in few hours on ThemeForest.
