Hi, I can see, thanks. Apparently Visual Composer overwrite our styles, we'll fix that in upcoming update. For now: Please go to Xpert Options >> Custom Style and paste this definitio:
.a13-button .hover a, .a13-button .normal a {
background-color: transparent !important;
Hey, just wanted to ask if this has been fixed? Because I have the exact same problem.
Already added the custom style, that you mentioned above: And also added "color: #5472d2 !important" to ".normal", because otherwise the caption was white, if the button wasn't hovered.
Anyway, the button still does nothing. And like ivanmazepa I couldn't find the option to disable the icon. Would really appreciate your help ;-)
I can see, thanks.
For now:
Thanks for help. I did first one http://www.evernote.com/shard/s27/sh/a844ce20-dfac-4826-be2c-9cdd4cd32013/f51e76a19a522e4f4a6b5345c15f9087
No result for front.
And I'm not really sure that I understand for second point. If its here (Page / homepage / Post grid edit... ), i don't see checkbox "add Icon" http://www.evernote.com/shard/s27/sh/2755f638-d89b-4d2e-b3f3-87542fee82f3/440d66bc805d63e115d11eec067c37dc
display:none;style at anchors, I'll take closer look.All the Best.
Regards,
Eggerd
please start a new thread and provide url to your website
