Hi Support Team,
My website is www.inspiretbb.com
I am trying to change my theme so i created a new path to test the theme.
www.inspiretbb.com/ar
I also installed WPML to test the Arabic content
English Version: www.inspiretbb.com/ar
Arabic Version: www.inspiretbb.com/ar/ar
How can I fix the layout alignment?
*Sorry about the double AR that might confuse you.*
Thank you.
I think it is Visual composer issue with not being RTL ready. Try solution form here http://support.apollo13.eu/discussion/comment/14773/#Comment_14773
It worked fine.
But the the menu on top of navigation bar.. the one for the language, phone number and email.. it's not aligned well.
In English it works fine but in arabic it's not.
Any ideas how to fix it?
So you use Thirteen theme or FatMoon theme? Cause you posted in Thirteen theme:-) FatMoon is not yet ready to be fully RTL theme, so they may be issues in such elements, and you may need to write custom CSS for them.
You can try such CSS for this issues: With kind regards.
