How do I remove the generated image that appears on the top of each default page
edited September 2014 in Blame Posts: 9
I'm trying to edit my website using this theme and I've noticed that this image appears on every page I generate. It seems to be built into the code. Can you let me know how I can remove this image.
    Hello AshleeS
    In the admin pane go to the "Blame Theme > Layout > Title Bar" .
    There you will find "Custom background image " for Title Bar.
    All the Best
    Lead Graphic Designer
  • I am in the admin pane (back-end) and can't find anything that matches your directions. Am I missing something? I too am trying to remove the image.
    There is one global setting like Daniel explained and one local like ASantiagoJr has shown.
    Which part you can't find nefy96?
  • I found it - I didn't go down far enough to find the "Blame Theme" menu. Silly oversight. Thank you everyone!
