How to edit text in WORKS
edited September 2014 in Blame Posts: 62
I found the edit panel is quite poor in terms of editing options. This is even no way to change the font size on a specific WORK page. Did I miss something?
    edited September 2014 Posts: 10,970
    Hello
    This is standard wordpress editor, you didn't miss anything. Are you new to Wordpress?
    vanillababy said: even no way to change the font size on a specific WORK page
    Changing font size across you works doesn't sound very good but maybe you wanted to just show an example :-)
    Btw. You can either activate Visual composer for works in its configuration, or extend standard editor with some plugins, and there probably will be font size controls :-)
  • Ohh...I had no idea it's a standard wordpress editor on your WORK. Now I see why it looks so familiar to me :)) If I don't mind there should be a nice plugin which adds a rich editing functionality.
