Custom Icons
edited September 2014 in Adamant Posts: 16
Is there a way to add custom icons as when I tried to do it, it was put in a box and reduced in size?
see attached for ss
    Hi there
    You have posted in Adamant category, but our moderator moved it to Beach Please category. However I can't recognize this theme on your screen shot. Could you tell which exactly theme are you using?:-)
  • Yea I am using Adamant :)
  • edited September 2014 Posts: 1,758
    Ok then.
    please post me an url to Your site, and describe more precisely where do you want to put custom icon, what are You trying to achieve.
    Post edited by surgeon on
  • I sent you a DM :)
