how to remove this white gap after the parallax image right before the footer?
edited September 2014 in Blame Posts: 44
See image
Post edited by kingcontent on
    You must disable the paddings: http://goo.gl/nvu0Oh
    Lead Graphic Designer
  • Hi under which section is this option available I can't seem to locate it.
  • edited September 2014 Posts: 422
    It is not a global option. This setting is only available in the page details (eg. contact, about, homepage etc.): http://www.apollo13.eu/docs/blame/#!/adding_new_pages
    Post edited by Daniel on
  • Found it thanks! I'm still getting a white space at the top of my webpage tough. When I inspect the element its telling me there is an h1 element there page title apparently. Is there anyway to turn this off?
    You have to also disable the "Title bar look". This option is located below the "Content Padding"
