Remove Image Title
edited September 2014 in Adamant Posts: 16
How do I remove the Image file title. Please view SS attached
    thank You for this report. There is a switch in Adamant Options panel which is supposed to do the job, but I've noticed that it's not working properly, so we'll have to fix it in the upcoming update. I'll inform You when it's ready.
    For now: go to Adamant Options >> Custom Style and add this definition:
    #a13-slider-caption {
    display: none !important;
  • Hi thanks for the help, I have done this however it doesn't work. Any other solutions? thanks
    Well, as far as we are talking about http://kinetikvs.co.uk/ - it worked fine.
    1150 x 720 - 114K
  • It seem's to have worked on some browsers but not on chrome?
    Chrome displays it correctly.
    1098 x 728 - 110K
  • Yep, sorry just had to refresh it quite a few times.
