When clicking an image Hypershot always displays the current filename above the page info (Image X of Y) for Albums.
My filenames are usually something along the lines of: IMG_4064 which is not helpful at all.
I know I can change the title of the image, but doing this for every image is annoying.
I think I could find the place to remove this, but then updating the theme could become a problem.
I see two solutions to this: Make this configurable per Album and or allow advanced users to maybe define a regex that registers their Cameras file numbering scheme ( in my case /0Z[A-Z0-9]+|IMG_[0-9]+/ would match both my cameras) and only displays the media title if it doesn't match the Regular expression
greetings Daniel
Regex solution is rather hardcore, and not user friendly or rather to hard for average user, but cool anyway :-)
So if you don't want to use this I advise custom CSS solution - it will stay across updates http://apollo13.eu/docs/hypershot/#!/modification_of_theme
Here is CSS http://support.apollo13.eu/discussion/comment/2712#Comment_2712
I will try to add such thing in new update:-)
