I got an earlier message that I must go into my po. mo files to translate, but how do I translate in these files? I want to translate the site to norwegian, or just some words...
Nevermind.. But I can`t find words like "loading", "load more", "visit site" "all" in the po-file ... I want to translate these words from my portfolio..
Those strings are a part of 'Visual Composer extend by Apollo13' plugin, so files to translate are inside this plugin folder (your_wordpress_installation/wp-content/plugins/vc_extend_apollo13/languages).
Hi. The translation didnt work. I followed the description.
I opened default.po, editet words to my language, saved as, nb_NO.po and nb_NO.mo, sat them in the same folder. Then editet wp-config.php. and sat, define('WPLANG', 'nb_NO');
nothing work, still english...
What texts you are translating? Is it 'LOAD MORE' text?
http://blog.tribulant.com/wordpress-2/wordpress-4-0-languagetranslation-not-loading/
