Hi!
I'm trying to integrate woocommerce in superior theme but sidebars is not showing in my main shop page.
I've read instructions and follow them: i've created a custom sidebar but it doesn't appear. can you help me, please?
look at: shop .culinaria.it
thanks in advance,
michela
First you have to create sidebar, but you already did it.
Next fill this sidebar with widgets in Appearance->Widgets menu.
Next go to Pages, find shop page, edit it, and there select proper sidear in option Sidebar to show.
Make sure non cache plugin is blocking you from seeing effects :-)
Hope that helps.
I've already did it but the sidebar is still not showing on the shop page.
I've cleaned my cache but nothing happens.
Maybe have I to change some template or page layout settings?
michela
