Not able to add demo data
edited October 2014 in Blame Posts: 1
I am not able to add demo data in my site. The backup data (blame.wordpress.2014-08-26.xml) you had provided is not a valid wordpress export file.
While importing it is showing that it is not a valid file.
Could you please look into my issue.
Regards
Sujith
    It is strange cause this file should be 100% valid, but you can try to use our one click demo data importer http://apollo13.eu/docs/blame/#!/installing_demo_data
    Anyway I am attaching xml file also.
    Hope that helps.
    zip
    zip
    blame.wordpress.2014-10-08.zip
    130K
  • edited January 2015 Posts: 4
    I suffer from the same problem as him, and i just downloaded the new xml file and it helps.
    Post edited by 32044053 on
    In your other topic I see you have managed, how you did it?
