Like to add a Facebook "Like" button on sticky menu
edited October 2014 in Superior Posts: 27
Could you tell me if it is possible to add a facebook like button on the the sticky menu next to the search icon - just one showing the number of likes so people can like the website.
Post edited by rad76 on
    Hi there:-)
    it would require custom coding and testing. Easier it would be to add it to footer in one of text fields.
    and thanks - I had a feeling that would be the case.
    With the footer do you mean just pasting the code from facebook in the footer text area of the Layout section?
    When I went to facebook it said there were 2 pieces of code I had to use -
    "Include the JavaScript SDK on your page once, ideally right after the opening tag"
    and
    "Place the code for your plugin wherever you want the plugin to appear on your page."
    Yeah, try pasting both things in text area. You can also try to find plugin for this and then position with CSS such button. Such plugin often give shortcodes so then we can work it out where to put it :-)
    Ok thank you I will try this :)
