For now I only want to show products on my site, without prices and heading to checkout and wishlist. How do I do this? I do want to add this later on.
So basically:
How do I remove the wish list button and checkout button from the image?
How do I remove the price shown and re-directing to checkout?
I could make it in a gallery, but then I have to change everything around when I will add the prices later.
Can you assist?
now I just want to remove the shoppingcard hover from the product image..
Someone tried this already. Searching...
Here http://support.apollo13.eu/discussion/comment/9478#Comment_9478
To deactivate wishlist you can just deactivate wishlist plugin:-)
Only thing is I can't get rid of the shopping trolley in the header still. How can I do that?
Also the sorting options dropdown Menu can I edit it? It says sort by price but I don't have prices anymore.
If you will still have problems then I will try to find solution for you:-)
About header cart you can try CSS solution http://support.apollo13.eu/discussion/comment/9575#Comment_9575
Or make it in code: go to functions.php file, and at bottom of it add this code: It will overwrite current function for displaying cart:-)
With regards:-)
