I'm trying to update the version I have on wordpress and its not letting me do it
I went to Appearance>themes and clicked on add new. I chose the new Fame zip file and clicked install. It never gave me any options to click yes for updating. When it went through the updating it gave the message
Unpacking the package…
Installing the theme…
Destination folder already exists. /var/sites/h/hannahadamaszek.com/public_html/wp-content/themes/fame/
Theme install failed.
Are you able to able or point me in the right direction?
Please follow updating instructions and use plugin for this :-)
http://apollo13.eu/docs/fame/#!/installation_update_update_theme
Plugin: http://wordpress.org/extend/plugins/easy-theme-and-plugin-upgrades/
If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks! How to rate?
Installing the plugin…
The package could not be installed. No valid plugins were found.
Plugin install failed.
Any idea?
It looks like something is wrong with your WP installation or server. Maybe not enough free space? It happens ;-)
However - have you tried updating theme by FTP? As explained here http://apollo13.eu/docs/fame/#!/installation_update_update_theme :
"If you have problems with updating theme from Wordpress admin panel, then delete theme (from panel or manually via FTP) and upload new version. It is same process as installing via FTP. You wont loose your theme settings."
If it wont help I will try to do it for you.
