Navigation Anchors: Problem when installing WP in its own directory
edited January 2015 in Chillout Posts: 2
Giving WordPress its own directory is a fairly common practice, and we like to do it on all of our sites.
This is then noted in the General Settings page, where the "WordPress Address (URL)" is different than the "Site Address (URL)". I'll attach a screenshot for our case.
WP Address vs Site Address
It looks like you guys grab the WordPress Address for the navigation anchors where you should probably grab the Site Address instead.
The navigation anchors will work on the homepage. However if you are on a subpage like /blog, they break. In our case they want to go to http://da3.wehearvoices.com/wordpress/#a13_nava_id_123
    Hello!
    Thanks You for the report, this bug will be fixed in upcoming update.
    The issue is crucial so the update will be released soon. I'll let You know when it's ready.
    FYI - new version of Chillout is ready to download from ThemeForest.
    Thank You again for the report.
  • Great, good to hear it. I'll go grab the latest version now.
