People / Team posts number
edited February 2015 in Chillout Posts: 63
Hello
how can i change the number of displayed entries in the team grid view?
There are only 8 posts, if i change the size of one there is a gap.
The only solution i found is to edit the a13_shortcodes.php and set the number to 9
Post edited by Tim92 on
    Hi
    Tim92 said: The only solution i found is to edit the a13_shortcodes.php and set the number to 9
    which line did You edit?
    You could increase size of one item - tha gap will vanish.
  • edited February 2015 Posts: 63
    line 324 'grid_teasers_count' => 9,
    i can't increase on item because i need 1 or 2 more
    Ok, the main idea was to narrow People posts by its categories. I've never thought about displaying not full team. But I can see now it was wrong way...
    So - this will be changed, and You'll have full controll over the number of posts to display.
    Thanks.
    That would be great.
    btw. i noticed that sometimes the text is not centered correctly in the people section
    you can see it on the screenshots
    to center it horizontally i reduced the right and left padding (german words... ;) )
    The title is not displayed because its not set in the "people" post.
    1049 x 1087 - 911K
    FYI - Chillout has been updated, and is available to download from ThemeForest. The shortcode 'Team' has been improved, and now You have a control over posts' count.
