Deal all,
We have just installed the template as demo version but the revolution slider on front page comes missing:
"slider with alias homepage missing".
The perso helping us has advised:
After login in your admin panel. You can see left menu bottom, "Revolution Slider" click that. After you see "Import Slider" green button. When you get slider zip file from that theme author you just install it from there.Then, goto pages > Home Page > First you see the element of "Revolution Slider" just edit and select slider. And Save It! That's All!
Can you please assist us with the issue?
Thanks.
so where You stuck?
If I understand right the slider is missing in the files.
Yes, it's in theme package. But it's not correctly import. It has issue, so kindly ask the live demo site import file.
Do You get any error message?
revolution slider error: slider with alias homepage not found.
It is third day I use WordPress.
Thanks for the assistance!
