Reduce font size for similar posts area only
edited March 2015 in Superior Posts: 66
After I updated the theme to the latest version, I noticed that the font size for the similar posts title under my single blog posts is huge. I tried changing the title using this:
.in_post_widget .post-title {
font-size:15px;
For some reason, it doesn't apply so it's still coming up huge. I also tried changing the single-post title but that changed the top of the post rather than the size of the similar posts title.
How do I change the size for titles in this area?
You can see an example at http://www.alexnavas.com/12-stones-principle/
    Hi there
    In your custom CSS you have
    .single-post .post-title {
    color: #028D01;
    font-size: 28px !important;
    Remove font-size: 28px !important; part.
    So it is not update related issue:-)
    Perfect. That solved it. Thanks
