Change the "Search" word to search logo
edited March 2015 in Blame Posts: 33
How to change the Search word of the sidebar to the search logo and want it at behind of the placeholder?
    I can explain how to change this word, but I don't understand second part of your question.
    You can do it either in translation file like explained here http://apollo13.eu/docs/blame/#!/translating_theme
    or in code in blame\advance\utilities\layout_parts.php line~47
    <input type="submit" id="searchsubmit' . $search_id . '" title="'. esc_attr(  __( 'Search', 'blame' ) ) .'" value="Search" />
    and change there all occurrences of Search.
  • What i mean is how to change the SEARCH to icon?
    1366 x 654 - 354K
    You will have to add such custom CSS for it
    .widget-area .search-form input[type="search"] {
    width: calc(100% - 53px);
    .widget-area .search-form input[type="submit"] {
    height: 38px;
    width: 38px;
    background: transparent url("image.png") no-repeat 50% 50%;
    text-indent: -9999px;
    padding: 0px;
    margin: 0px 0px 0px 10px;
    And change image.png to proper URL.
  • Thanks you so much for your helps.
  • Hi, there.
    I find out that the safari and the internet explorer does not support the WIDTH css.
    Url: http://imtinyscribbles.com/.
    1024 x 738 - 917K
    edited March 2015 Posts: 10,970
    What safari version? 5? It is kind of buggy browser. And what version of IE? Probably 8, right?
    Anyway calc(100% - 53px); is supported only by newer browsers. I think you shouldn't bother with old ones in this case, as user don't loose functionality.
    If you still want to, then you will have to rewrite this styles to either use floats, or absolute positioning.
