Meta name "keywords" / Meta name "Description"
edited April 2015 in Chillout Posts: 9
How can I add and edit the
–Meta name "keywords"
–Meta name "Description"
Would you please advise, ^^ I'm didn't know much about at coding
    this is for SEO purpose, right?
    If so - please use some SEO WordPress plugin (one of the best it here: https://wordpress.org/plugins/wordpress-seo/ - it's very well documented)
    If not - look here: http://www.w3schools.com/tags/tag_meta.asp
    One more thing - header.php is the file, where You put this meta tags.
  • Thank you, I will try both plugin and the coding.
    by the way, at line "16 "..
    If I remove the line " 16 "...will my site description gonna appear when search in google ?
    Thank you again, You guy are very...5 star ..service ^^
    1368 x 365 - 245K
    702 x 124 - 26K
    change it to:
    <meta name="robots" content="index, follow" />
