Menu Customization Request?
edited April 2015 in Chillout Posts: 1
Love the theme. It works great. I am wondering if you do custom css change requests? I'm trying to edit a menu item on the main navigation, and I'm just not able to get the spacing correct on it and remove the transition effects... I'm just trying to give it a gradient that will match the full width of the navigation bar.
I have a screenshot showing the desire effect, and the gradient css is done.
You can see it here: http://prosecretsofgolf.com/ - it is the 'buy now' link.
Would you be able to help me out?
    I'm very sorry for the delay. I'll get back to your request tomorrow.
