Can you give more details? Does it not save settings, or after save, it returns to default? D o you have any notification in you admin panel(please login and see top area).
Probably some simple issue, so together we can work it out:-)
Could you please send me temporary access(create new ADMIN account with fake e-mail) to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option "Send Air a Message"). In message please attach LINK(!!!) to topic it applies to.
It is caused by your SuperCahcer plugin. Even deactivated it still affects cache. I had to activate it and press button "purge cache" after each setting changed. You will have to remove it probably or remember to clean cache after changing settings.
Such plugins should used only after you are done with setting up your site.
D
change settings in panel doesn't change anything, btw It seems to be just a menu settings issue. No notifications in my admin panel
