http://youdigitalmarketing.com/ I'm using demo menu (modified) as main at the moment but any time i set as main menu the one i created i get that problem (update)i'm getting the same issue with demo menu using anchor links
OK I found it, it issue in our script when anchors are used. Instead of using just #about-us in your links in menu you will have to use http://yoursite.com/#about-us and it will work :-)
It is cause you used different domain then your site really is. http://yoursite.com and http://www.yoursite.com ARE different domains, and you site works under http://yoursite.com, but in links you have used www. That is why browser redirects you.
Sorry to bother u again, just to let u know the script issue affect the website even with http://yoursite.com/#about-us exactly it affects the menu in pages (Not in home), it disappears, and portfolio page, the works are not loading
O man, what a buggy code I wrote. Now I see what circumstances I didn't take into account. Thanks for your patience and sorry for issues. Use this file from attached ZIP archive and upload it to blame/js
It will fix issue. Remember to clear cache in browser while testing(ctrl+F5).
#about-us
in your links in menu you will have to usehttp://yoursite.com/#about-us
and it will work :-)I will fix it in next update.
thanks
