Hi! I set a Tile hover color on all of my tiles but they don't show up. The colors also don't show up in the source code. Can you help me?
I'm running WP 4.2.2 + CeeVee + Childtheme (there is no CSS in my chiltheme yet, so that can't cause any troubles…)
Hi surgeon, I figured out hover colors are not supposed to work without an image? Anyway I edited a13_extra_params.php and added $unique_tile_styles .= '#'.$unique_tile_id.':hover .a13_tile_color{background-color: '.$tile_hover_color.';}'; to Line 557.
Was that a bad idea?
Anyway - we're going to change the way it works now. Thanks to You.
Next update will have this issue fixed in order to be more flexible.
Thanks again.
