Hi, i just discovered that my wooccomerce version is 2.3 and not 2.1. There is an error on credit card payment page and stripe company says the problem is due to the version incompatibilities cause the fame theme only supports woocomerce 2.1. can you please update the version i bought so it can be compatible with WooCommerce 2.3?
Here is the error i get when i try to put the payment through; ''PLEASE MAKE SURE YOUR CARD DETAILS HAVE BEEN ENTERED CORRECTLY AND THAT YOUR BROWSER SUPPORTS JAVASCRIPT''
What version of theme do you have? Cause Fame was long ago update to support Woocommerce 2.3, check change log http://www.apollo13.eu/themes_update/fame/index.html
I don;t know where to get the version number but here is the link of the theme i bought. I bought it a month ago. I guess it should be the latest version.
http://themeforest.net/item/fame-responsive-multipurpose-wordpress-theme/7668633
However as you say it should be alright.
I wonder how "stripe company" can tell if it is theme fault or not.
If you had woocommerce 2.1 with Fame bought month ago then it is something fishy about it, cause WC 2.1 was loooong ago, like year ago. Have you just changed theme on your working site, or you started your site after buying fame theme?
For me it sound like misconfiguration of WC, but Lets start with you updating theme.
Theme version you check by clicking on theme, see screen
How to update you will find here http://apollo13.eu/docs/fame/#!/installation_update_update_theme
If this wont help we will try on other theme to see where issue lays.
1. Can you tell me more how can I recreate this issue?
2. What is your theme version?
3. Have you update theme?
