Request
in Photon Posts: 19
is possible to insert a X on the top right to close the sidebar? For example on iPad it is difficult to close.. You see scree attached for example.
regards,
Andrea
    Why do you think it is difficult to close on iPad? You just tap other part then sidebar and it closes.
    excuse me, no in iPad, but on iPhone It is difficult. You see scree attached..
    Regards,
    Andrea
    640 x 1136 - 67K
    Indeed in vertical mode it can be hard. We will think about "X". Thanks for idea.
    when the next update of the template?
    Regards,
    Andrea
    Possibly today.
