Album dropdown
in Spaceship Posts: 10
Hi again. I'm still building my homepage, and I have several albums with photos now. It works very well, but I have a question:
How do I make a drop-down-menu, so that people can choose album-category from the frontpage? I see that you have a drop-down on the Spaceship-preview, as I have attached to this post.
Best regards :)
Jacob
    Oh, and I forgot this question:
    Is there any way I can change to language on the contact-form? I want to translate it to danish, and I will translate it myself, if it is possible. :)
    Hello there:-)
    Skuddi said: How do I make a drop-down-menu
    Check image
    Check this http://apollo13.eu/docs/spaceship/#!/translating_theme
    923 x 407 - 32K
  • edited June 2015 Posts: 10
    Thank you, although I have a problem.. I thought it would be there, but I don't see the option.
    This is all I see.. How do I add My Albums to the left menubar?
    I see that I can make a dropdown by using the Custom Links, and then just type in the URL of the album, but the other way would be faster.. And I don't understand why I can't see it, when you can :-)
    1000 x 627 - 123K
    Post edited by Skuddi on
    And also, I did set one page to be an album, so I should be fine, right?
    I just can't see 'My albums', in Appearance > Menu
    1200 x 393 - 102K
    Ahhh, I hadn't checked 'My albums' in 'Screen Options'.. Now it works. Thanks! :-)
    Great you have solved this. I thought in new WP it isn't hidden by default.
