Hi again,
I wanted to set the products with two differents additional info:
- a bubble with a percentage off on top right of the picture (on the place of the SALE! label you have as default)
- a label with "Free Shipping" beow the pic.
I bought the woothemes plug-in "woocommerce advanced label" but it seems that it's not worokking as I think your theme code come first and it doesn't allow that plug-in working...
Is there a way to let this plug-in working or at least display in some way the percentage of discount?
I hope I've been clear with my english... :-)
2. I will need access to this plugin so I could check which filter it uses to display this labels. If you can please send it to info@apollo13.eu
1. customizations in theme
2. changes by this plugin
Are not easy, as it looks like it would require modificating plugin, or advanced overwriting its actions/filters.
As I said before It will remove some of our styling, but it will make this plugin work.
Other way is to go to fame\woocommerce\content-product.php line ~47 and under
do_action( 'woocommerce_before_shop_loop_item' );add thisdo_action( 'woocommerce_before_shop_loop_item_title' );This will produce double image, but then we can try to make something with CSS.
Try it first.
.wapl-flash{Tested, works for me :z-index: 5; /* take label above image */
.woocommerce-page ul.products li.product > img{
display: none; /* hide image from plugin*/
sorry for not answering yesterday but internet was not working.
I did as you told me and it seems working.
I need a pleasure if you know how to do it.
I need to put the labl "Free Shipping" I have in the image not above the picture box but just under between the picture and the product title. This should be the normal position but with these changes it has gone there.
I've been tried to use the css (where I'm not really a genius!!)
.wapl-label {
position: relative;
top: -200px;
but if the label in the bigger pics go in the right position on the little picture on the right disappear.
So do you have any idea of how to put it just under the picture?
Gabriele
from the plug-in I gave you yesterday (if installed) you should go to woocommerce--settings and press on Global Labels and then you can create the labels.
OK, so instead of hiding plugin "product image" lets hide theme's one.
Instead of previous CSS try this With kind regards.
i will check it later as I'm outside... This css will keep the circle up and the free shipping label down?
Try adding such custom CSS: It will push star and cart higher.
label's perfect...
For the space on the top rated rpducts I set 3 colums and 2 products, but even with two products the writings go on the others... I mean on IPad...
There is just not enough space there so you could display 3 normal products, and set of small products in same row. You have to break it in two rows to have good effect. They just can't behave correctly in this kind of layout.
That what I was trying to say previously :-)
Am I right? Or is there a way to set 2 colums for the top rated space?
I will send Daniel here.
Here is screen shot of my solution:
I think you could make some rules in VC that will tell it when row should be broken on lower resolution. However I have never used it and I don't know if this even work as I described :-)
I don't know anything of css or programming so I have to find secondary solutions.. aaahaha
To have it like on our demo page you have to follow his instructions and put there sidebar. Have you done that already?
I found out this new problem .. (actually it casued on this same title's item)... when I pass on a picture with cursor I cannot select it...
I saw that the problem should be caused by this css you gave me
.woocommerce ul.products li.product a.thumb {
display: none;
Before this css I have two same pictures of the same product (as you told me once), one not checkable and the other working fine.
By inserting this css the image become just one, but I cannot press on it... any idea how to solve this?
I will put the site online again ..
thanks
Here is complete solution, remove ALL things we did previously.
Next do as follows:
Custom CSS: Go to fame\woocommerce\content-product.php line ~106 and before
echo '<div class="product-meta">';add thisdo_action( 'woocommerce_before_shop_loop_item_title' );Effect(link working, all theme things works):
This should end this case:-)
let me thank you with another donut.. :-)
Have a great day.
how are you today? I got a new issue for you under this post.
Remember you solved me the label displaying? It works fine, but it works only with discounted prices set on product page.
I'm explaining better....
I'm using a plugin that allows to set discounted prices directly to a category - dynamic pricing (from woothemes).
When I set for istance a discount of 10% on one specific category only the price at the button change, the label "sale" and the discount bubble don't show.
Any idea of how to set this?
thanks a lot
Thanks, lately I am working hard to move our team forward, and it is lot of new things to learn for me, and many are not obvious. You asked ;-)
Main question:
I don't think that plugin that you mention work in same matter as default sale mechanics. It must affect prices directly, not via sale. Label of "sale" only show when
$product->is_on_sale()returnstrueand this is default woocommerce mechanics for that.Maybe you have to mark some bonus option in that plugin so WC would know it is on sale.
Seek answer for that with this plugin author, as he/she will know more :-)
I will told them..
