Error with slider in my works
in Chillout Posts: 15
When making a slider in the post get the following error in the debug of the browser "Uncaught ReferenceError: Blazy is not defined"
Please check this urgent need to fix it.
my website: http://www.garage-ibach.ch/website/
the option in my works: DIE MAKERLLOSE LACKIERUNG
    Hello Angela,
    thank You for this report, I'll fix that ASAP and will provide You a quick_fix for You before releasing next update.
    Hello again,
    I've attached fixed file for You. The file's path is ..\wp-content\themes\chillout\js\plugins.js
    Just replace it with one I send You.
  • edited July 2015 Posts: 1,758
    Here's the file.
    Unpack it first.
    zip
    zip
    plugins.zip
    16K
    Post edited by surgeon on
    hi,
    thanks, works but the title and category appears at the top of the slider and not under like the other items, you can change or where setup this??
    the title is supposed to display under the featured image only - it's part of the layout's design.
    In this case the title is displayed over the media collection of this Work Item.
    If You want to change this - You would have to alter the file: ..\wp-content\themes\chillout\single-work.php
