Hi my friend,
I do have this question, but I'm not sure if I'm a dumb and it has to work in this way or what...
I deactivated the maintenance mode to let you see it - website www.italiaamoremio.it
The problem is:
if I digit the word "rice" in the search box the result are manies and not all regarding rice that are put in random way in the search result.
Is there normal, is that something to to with the them or something to do to wordpress or woocommerce?
Thanks for helping...
gab
I clicked on one wine that shows up in result for "rice" search query, next I searched for "rice" in that page and I found word "liquorice".
This is pure wordpress case and how its search algorithm work.
