I have to many categories i would like to keep it simple but when i put the categories to drop down it will over lap please see image i had to revert it back for the mean time
You have to have there very long name, and it looks like woocommerce didn't style this for such case. However I tried this widget, and it looks like traditional <select> form input. Did you use some plugin to make it look like this?
i tried another theme just to see what would happen heres is what happened when i tried twenty fourteen (black background image) the built in wordpress font compared to fame (white background image) so is this now a coding? everything works and fits perfect in the side bar but on fame it overlaps and not all widgets work?
where do i ass this sorry not very familiar with css. and what can i do about the widgets with the others not showing? for ex. you see filter by price and the other it doesnt show
forty2group said: what can i do about the widgets with the others not showing? for ex. you see filter by price and the other it doesnt show
I assume "other widgets" are also woocommerce one? Most of these widgets are context dependent. It means they will only show up on shop page. If you trying again to insert them on normal page where you inserted products with shortcode, then it wont work.
<select>
form input. Did you use some plugin to make it look like this?With kind regards.
No clue, maybe some conflict with some plugin?
To fix it, add this custom CSS I will also add it to theme.
Thanks for this!
Adding CSS -> http://apollo13.eu/docs/fame/#!/modification_of_theme_custom_css I assume "other widgets" are also woocommerce one? Most of these widgets are context dependent. It means they will only show up on shop page. If you trying again to insert them on normal page where you inserted products with shortcode, then it wont work.
You have to add it to sidebar in main shop page.Read this http://apollo13.eu/docs/fame/#!/adding_woocommerce
