Hello once again,
I'm trying to display more than just 12 products on the shop page but, when i change it to 4 columns it will scatter the images please check the link. its only with fame i have all these issues if i change to another theme i dont have the issues.
Lucky you have posted one in different topic.
I asked before how did you change from 3 to 4 columns? I believe you again mean this static page http://www.melectr.com/shop/full-collection/ where you probably used some shortcode to get this product list there.
On your main shop page http://www.melectr.com/shop/ you have 4 columns.
However If you want to put sidebar + 4 columns product then:
1. Theme is not prepared for such case. You will have 4 columns without sidebar, and 3 with sidebar.
2. It won't look good(and this is reason why theme works like I described in point 1).
