Hello, is there a way to exclude specific albums from the album list? E.g. if I want to not show a password protected album in the album list or want to make different album lists each with different albums? That would really be helpful!
Hello there, I also would appreciate that function. e.g. I use a album for the home page. This album should only be visible there not as a album in the album list. So is there a way to disable single albums?
You can create just different albums list by assigning all albums that you WANT to display to one category. More info here http://apollo13.eu/docs/photon/#!/adding_multiple_albums_list_and_categories
If you need more info, please ask.
Current way to achieve what you ask is described above. However now that you have exactly explained use case I will add soon such option.
Thanks again.
