Hello Apollo, How does the Grid mode work on the works section? Is there a measure? every time it changes randomly? is there a grid template where we can see the measures? can we edit this? Thanks a lot.
Yes, like I want to know if there are any rules. For example if I build different image sizes but upload them in order then the greed is respected . In the main page, at work section Everytime I upload a new project the grid changes all. This is annoying as I don´t know what is happening.
OK, I think I know what is your concern. The Work Items are organized with packery script ( You can take a closer look how it works here: http://packery.metafizzy.co/) So - basicaly - this script tries to fit the items it the way that in the end there as few gaps as it's possible. You can controll the order of displaying by two parameters highlighted on image I've uploaded, but the script will try to reorder item to reduce gaps. You can alse change the size of certain Work Item by editing it and altering the 'Item size' parameter OR You can edit Home Page, edit the 'Works list' shortcode and change 'Layout mode' to 'fit rows'
597 x 785 - 69K
Grid mode - this is the way of displaying media collection when You view work.Like here: http://www.gorilafilms.com/work/trading-branding/
Is this what You were asking about?
Are You talking about Work items grid
OR
grid of images within one work item.
You could post me two screenshots as an example of things that are changing.
OR
You are welcome!
Do not hesitate to rate Chillout!
